Dust Shoe
Below are the video instructions for assembling your dust shoe.
Clear Cut Dust Shoe
For the ATC version of the Clear Cut Dust Shoe, please see this page.
Usage guidelines:
  • You can remove the bottom section of the dust shoe when changing out your tool
  • If you are using the Clear Cut Dust Shoe on the LongMill, please note that machine travel may be reduced
80mm Dust Shoe
Usage guidelines:
  • We recommend to take off the dust shoe when surfacing, since the machine is moving to its limits the dust shoe can get damaged
  • Feel free to adjust the dust shoe using the hose clamp. We recommend positioning it so that it faces along the Y-axis so it does not interfere with your cutting jobs
