1. Unboxing 📦
Make sure you have all the parts you need for a smooth and painless assembly; open all boxes and unwrap the parts! Do not unwrap the plastic on the left and right Y-axis rails until table assembly is finished. Some parts are stored inside the gantries and rails, so check there too.
AltMill Kit Parts List
X-Axis Rail Box
- 1x X-Axis Assembly
- 2x Drag ChainÂ
- 1x Power Supply
- 1x 80mm Spindle Mount
- 3x Crossbeam Extrusion
- 1x 4mm Hex Key
- 1x 3mm Hex Key
- 1x AltMill Wrench
- X-Axis Fastener Bag
- M4-16mm Socket Head Cap Screws
- M5-10mm Socket Head Cap Screws
- M5-16mm Socket Head Cap Screws
- M6-25mm Button Head Cap Screws
- M6-35mm Button Head Cap Screws
- M6 Shoulder Screws
- M5 Nylon Lock Nuts
- M6 Flat Washers
- Table Assembly Fastener Bag
- M6-12mm Button Head Cap Screws
- M6-16mm Button Head Cap Screws
- M5-8mm Button Head Cap Screws
- Crossbeam M5-16mm Socket Head Cap Screws (without Loctite)
- M6 Roll-in T-nutsÂ
- M5 T-nuts
Y-Axis Rail Box
- 1x Left Y-Axis Assembly
- 1x Right Y-Axis Assembly
- 4x Y-axis End Plate
- 2x Crossbeam Extrusion
- 2x Dust Shield
Main Box
- 4x Table Leg
- 1x Left Y-axis Gantry Plate
- 1x Right Y-axis Gantry Plate
- 3x Stepper Motor
- 1x Z-Axis Assembly
- 4x Leveling Feet
- 4x Motor Cable
- 4x Inductive Sensor
- Small Parts Bag
- 2x Eccentric Bushing
- 1x Drag Chain Bracket
- 6x Bump Stop
- 3x Coupler
- 10x 3D Printed Cable Hanger Clip
- Zip Ties
- SLB-Ext Box
- 1x SLB-EXT Controller with Enclosure
- 1x 3D Printed E-stop Mounting Bracket
- 1x SLB E-Stop Assembly
- 1x SLB E-Stop Cable
- 1x USB-C Cable
- 1x SLB-EXT Mounting Bar
Spindle Kit Box
- 1.5KW Spindle
- 1x VFD Mounting Bracket
- Spindle Accessories Bag
- 1x ⅛” ER16 Collet
- 1x ¼” ER16 Collet
- 1x ⅜” ER16 Collet
- 1x Spindle Wrench
- VFD UnitÂ
- 1x VFD AC Power Cable
- 1x VFD Control Cable
- 1x Spindle CableÂ
- Dust Shoe Box
- 2x Dust Shoe Bristle Holder
- 2x Bristle Strip (one longer, one shorter)
- 1x Dust Shoe Hose Mount
- 1x Dust Shoe Spindle Mount
- 2x Hose Clamp
- M4-25mm Screws
