Squaring & Tramming
X-Y axis squaring
The AltMill 4×8 is set up by default to use ‘dual homing’ in the Y-axis direction. This makes it possible to easily adjust the squaring of the machine in the XY directions, as well ensure the machine automatically squares itself every time the homing cycle is run. Out of the box, the machine is likely to be nearly perfectly square, but in some cases, small adjustments are needed.
1. To figure out how square your AltMill is, you can use gSender’s built in XY Squaring tool, found in Tools. If your machine is not square, this tool will inform you of some distance that either the left or right Y-axis gantry should be moved forwards or backward.
2. Once you have this distance value,  go to Config. Under Homing/Limits, scroll to find Y-axis dual homing offset.
3. Input the distance value:
  • Setting a positive value will cause the right side of the machine to stop slightly forward after every homing cycle (turning the whole gantry clockwise).
  • Setting a negative value will cause the left side of the machine to stop slightly forward after every homing cycle (turning the whole gantry counterclockwise).
4. Press ‘Apply Settings’, then turn OFF/ON the controller to have the change take place.
Machine tramming
Tram adjustment, or ‘tramming’ (the act of adjusting this) essentially refers to the alignment of the spindle/router’s rotating axis to be perfectly perpendicular to the movement of the X-axis (usually referenced by the actual machine bed/wasteboard).
On the AltMill, tram alignment is preset by a series of precise reference edges and alignment tools through the frame and gantries. At the spindle mount, tram alignment is set by the use of two shoulder screws. Using these as a ‘default’ will generally mean that your machine should be quite well trammed, but in some cases, a small adjustment may be necessary.
Checking for tram alignment will typically be done using a tramming arm tool which holds one or two dial indicators, used to ‘sweep’ across the bed/wasteboard surface to find high and low spots. Some specialized tools such as the SST tram tool exist to make this easy, but it is otherwise possible to find a way to mount a dial indicator to the rotating axis of your spindle.
Tilt
1. Take out the bag of eccentric bushings that came with your machine.
2. Swap the left shoulder screw, to use one (1)  eccentric bushing, and an M6-25mm button head cap screw inside this hole instead. Slightly loosen all four screws securing the spindle mount to allow the mount to pivot.
3. To finely adjust the tram of the spindle, use the small end of the included AltMill wrench to carefully rotate the hex of the eccentric bushing as shown below. Depending on where the eccentric bushing is angled, turning the wrench will cause the spindle to move some small amount.
4. For very fine adjustment, it may sometimes be necessary to gently knock the top of the spindle with a small rubber mallet, or the back of a screwdriver handle. Once finished, simply tighten all four screws.
 Nod
Warning – Do not use eccentric bushings to tram in the nod direction!
This cause misalignment between the ballscrew and the motor, which leads to premature wear on the motor.
Please follow the instructions below for the correct method to tram in the nod direction.
1. Jog the machine upwards to access mounting screws.
2. Loosen the 2 shoulder bolts, and the 4 mounting screws. Do not remove them.
4. Use shim stock or a cheap set of feeler gauges for your adjustment.
To adjust:
  • To tilt the spindle forward, shim beside the 2 top screws in between the plates
  • To tilt the spindle backward, shim beside the 2 bottom screws in between the plates
5. Tighten the screws and shoulder bolts.
