VFD Settings
You may find that your VFD unit is ‘locked’ from making any changes to prevent accidental changes that will affect your spindle kit’s functionality. Below, we’ll go over how to unlock that should you need to make any changes. We advise against unlocking and changing any of the parameters on the VFD unless you’ve been instructed to by Sienci Labs customer support.
Unlock VFD
To unlock the VFD parameters to allow changes to be made, you’ll first need to modify one parameter, or ensure this is already set to allow changes:
Navigate to the parameter ‘F000’, then press the UP or DOWN buttons to set this value to 0, then press ‘SET’ to save this.
Change VFD Parameters
To modify values, press the ‘SET’ button to enter the parameter selection screen. Here, you’ll see parameters ranging from F000 to F199. Use the UP and DOWN buttons to select the parameter you’d like to modify, then press ‘SET’ to select that parameter.
Once in the parameter you’d like to change, use the UP and DOWN buttons to modify this. When done, press ‘SET’ again, to save the value and exit the parameter modification screen. If you’d like to exit the screen without saving the modified parameter, press the ‘ESC’ button instead.
See these lists of parameters for the Sienci Labs Spindle Kit:
For both lists, parameters which should NEVER be changed have been highlighted in RED. Do not modify these unless instructed to. Any damage resulting from changes to these parameters is not covered by warranty to this spindle kit.
Parameters highlighted in BLUE are the most important parameters to verify.
PWM Control on Spindle Kit
While the AltMill Spindle Kit is set up by default to use RS485 serial communication, it is possible to use PWM (pulse width modulation) to control the operation and speed of your spindle instead. This can be useful if you’re having trouble using RS485 communication for any reason, or if you’re setting up this kit on a machine that does not have RS485 communication capability.
To set up PWM control for machines using the SLB or original LongBoard, you’ll want to set these parameters on your VFD panel, following the process described above:
Manual Control on Spindle Kit
You can control the spindle manually using the front panel of the VFD, and adjust the speed using the small knob.
To set up manual control for machines using the SLB or original LongBoard, you’ll want to set these parameters on your VFD panel, following the process described above:
Auto Control on the Sienci Labs Spindle Kit
To reenable or set auto control,  you’ll want to set these parameters on your VFD panel, following the process described above:
Parameter Value Name of parameter Description
F001 2 Control Mode Sets VFD to be trigger run/stop by the controller
F002 2 Speed Selection Sets spindle speed to be controlled by the software
