LongMill with SLB
Router Installation
If you have an existing router or spindle, unplug it from power. Undo all drag chain clips and remove the power cord of the old router. You can use a sturdy flathead screwdriver to pry the clips open at the side. Loosen the two M5 screws in front of the router mount and remove the existing router or spindle.
Place the AutoSpin into the 65mm mount, orienting it so the cables are on the left side, then securely fasten the two M5 screws at the front of the mount.
Guide the AutoSpin signal and power cables through the drag chain, then close the drag chain clips to secure the cables in place.
Wiring
Open the controller case by unfastening the thumbscrew and sliding off the cover.
First, remove the existing 5-pin connector that is on the spindle port.
Then replace it with the new 5-pin connector from the pigtail, plugging it into the spindle port on the controller.
Close up the controller and power it ON. Make sure to leave the router unplugged until a later step.
Firmware Setup
gSender Version 1.5.0 or newer
Connect to your machine through USB or ethernet.
Navigate to the “Config” tab at the bottom left corner.
On the left side menu, select the ‘Spindle/Laser’ option.
You will be navigated to the Spindle/Laser section. Select the ‘Setup AutoSpin’ button.
Your SLB will start flashing lights, indicating that the settings are being uploaded. Press OK on the popup window, then as mentioned, reset your SLB by turning it OFF then ON.
Reconnect to gSender. Go back to ‘Config’ and under Spindle/Laser, toggle ON ‘Enable Spindle/Laser functionalities.’
Press ‘Apply New Settings’ at the bottom right of the screen.
gSender Version 1.4.12 or older
Download the firmware setup g-code for the SLB:
AutoSpin T1 Setup (SLB)
Open gSender and connect to your machine, then select “Load File” and open the downloaded g-code file.
Select “Start Job”, the visualizer will not show a design, but the g-code should finish running within a few seconds. The big status LED on the SLB will also flash a few times to indicate that the settings have successfully loaded.
Power cycle the SLB by turning it OFF, then back ON. This is necessary to ensure that the new firmware settings take effect.
Select the gear icon and navigate to the “Spindle/Laser” tab.
Turn ON the Spindle/Laser toggle to enable spindle controls.
Testing
On the main gSender screen, go to the Spindle/Laser tab at the bottom right corner. Ensure you are on Spindle Mode, and you are using PWM or SLB_SPINDLE.
You can then use the speed slider and ‘CW (M3)’ or ‘Forward’ button to test the router at different speeds. Press ‘Stop (M5)’ when you are done.
Using PWM option
Using SLB_SPINDLE option
