ATC Specifications
What’s Included in the kit
In each ATC Spindle Kit, you will receive:
- 2.2KW ATC Spindle
- ATC Spindle Mount
- Enclosed 2.2KW VFD and Mount Adapter
- Clear Cut Dust Shoe
- Tool Length Sensor
- ATC Expansion Board for an SLB-EXT Controller
- 2.2KW VFD NEMA 6-15P Power Cord
- 10M Length 8mm Air Line Tubing
- Male 1/4″ NPT to 8mm Air Line Push Fitting
- ER20 Collet Wrench
- All cables and harnesses
For the specific ATC Spindle Kits:
ATC 6-Tool Rack Kit
- 1 Tool Rack (holds 6 tools total)
- 6 ISO20 Tool Holders
- 12 ER20 Collets, for 1/8″, 1/4″, 3/8″, 1/2″ bits
ATC 12-Tool Rack Kit
- 2 Tool Racks (holds 12 tools total)
- 12 ISO20 Tool Holders
- 24 ER20 Collets, for 1/8″, 1/4″, 3/8″, 1/2″ bits
ATC Spindle Only
- 3 ISO20 Tool Holders (No tool rack)
Not included in the ATC Spindle Kit:
- AltMill CNC Machine
- Computer or laptop
- End mills or bits
- Air regulator and filter
- Air compressor
- LED light strips
Compatibility
Machines: All sizes and models of the AltMill are compatible with our ATC. Our ATC is not compatible with third-party CNC machines.
Reduction in Machine Travel (Y-axis):
5.3″ from the back of the machine, accounting for clearance for the Clear Cut Dust Shoe.
Remaining Machine Travel (Y-axis):
- 2×4: 20.3″
- 4×4: 43.5″
- 4×8: 99″
Note that the tool rack is detachable, so it can be removed to free up the full cutting area.
Minimum Requirements
Electrical
ATC Power: Air manifold, pressure and temperature sensors utilize the SLB-EXT’s existing power supply.
Total System Power:
3 separate electrical circuits, to provide:
- 110 VAC 15A single phase for the AltMill (SLB-EXT with ATC hookup), dust collection, and computer
- 220 VAC 15A single phase for the 2.2KW spindle
- 110 or 220 VAC 15A single phase for your air compressor
Customer Supplied Air Compressor
- Operating Pressure: 100 psi
- Airflow: 3 CFM (ft³/min) at 90 psi or better
- Filter: 40 µm or better, coalescing type
- Dryer: More information to be provided
Product Details
Spindle
- Output Power: 2.2 kW
- Speed: 7,500–24,000 RPM, constant torque beginning at 18,000 RPM
- Collet: ER20
- Bearings: Ceramic
- VFD power plug style: NEMA 6-15P
ATC
- Cooling: Air cooled with 24V fan
- Operating Noise: 60 dBA at 24,000 RPM
- Tool Holder: ISO20
- Collet Type: ER20 collets
- Tool Rack Size: Maximum tool diameter 2″, maximum shank diameter 1/2″
- Number of Slots: 6 or 12 (configuration dependent)
