1. ATC Unboxing
Make sure you have all the parts you need for a smooth and painless assembly; open all boxes and unwrap the parts. Check for missing parts using the lists below.
Package Contents
ATC Box
Part Name Qty Notes
Sienci ATC 1 In foam
ISO20 Tool Holder (Spindle Only Kit) 3 In foam
MicroSD Card 1
ATC Shield (SLB-EXT) 1
RJ12 Cable – 0.2m 1
M4 – 8mm Flat Head Screw 7
M5 – 10mm Socket Head Screw 7
M6 – 14mm Button Head Screw 8
M6 – 25mm Button Head Screw 5
M5 Lock Nut 5
M6 Shoulder Screw 2
Eccentric Bushing 1
4mm Allen Key (Ball end) 1
2.5mm Allen Key 1
2mm Allen Key 1
1/2″ NPT Straight Fitting (8mm) 1
ATC Drag Chain Arm 1
Z-Plus Drag Chain Bracket 1 2×4/4×4
ISO20 Wrench Set 1
2.2kW Enclosed VFD 1
VFD Controller Cable 1
VFD Mounting Spacer 1
M5 – 30mm Socket Head Screw 4
M5 Lock Nut 2
Sienci TLS 1
TLS Cable 1
M5 – 10mm Button Head Screw 2
M5 T-nut 2
Z-axis Drag Chain 1 2×4/4×4
Plug-In Spindle Cable 1 2×4/4×4
Plug-In Spindle Cable – 7.2m 1 4×8
ATC Signal Cable 1
8mm Pneumatic Tubing 1
240V VFD Power Cord 1
ER20 Collet Set (Spindle Only Kit) 1 12 pcs
ATC Mounting Plate 1
Cable Clips 4
Cable Ties 4
Dust Shoe (Packed in ATC Box)
Part Name Qty Notes
Upper Dust Shoe 1
Lower Dust Shoe 1
4″ Hose Clamp 1
Clear Cut ATC Bracket 1
Clear Cut ATC Front Gasket 1
Clear Cut ATC Rear Gasket 1
Clear Cut ATC Slider Bushing 2
ATC Hose Bracket 1
M4 – 4mm Button Head Screw 4
M5 – 16mm Socket Head Screw 4
M6 – 14mm Button Head Screw 2
M6 Washer 3
Dust Shoe Handle 2
Filter Regulator Box (Add-on)
Part Name Qty Notes
Auto Drain Filter Regulator 1
3/8″ BSPP Straight Fitting (8mm) 2
Quick-Disconnect Ball Valve 1
Tool Rack Box (6 Tools)
Part Name Qty Notes
ISO20 Tool Holder 6
ER20 Collet Set 1 12 pcs
Tool Rack Backbone 1
Front Rack Section 2
Back Right Rack Section 1
Back Left Rack Section 1
Support Extrusion 1
Tool Holder Clip 10
Tool Rack Knob 2
M4 – 8mm Button Head Screw 20
M5 – 16mm Socket Head Screw 5
M6 – 8mm Button Head Screw 12
M3 – 20mm Socket Head Screw 2
M6 Twist-In T-nut 5
M6 Roll-in T-nut 7
ATC Rack Sensor 1
ATC Rack Sensor Cable 1
Cable Clips 4
Cable Ties 4
