Driver Power Supply
Parts list:
- LaserBeam 12V 8A power supply
Locate the power supply and insert the female AC cable plug into the power supply.
AC cable plugged into power supply
Plug in the other end of the AC cable to a power outlet that supplies 100-240VAC.
Power supply plugged into 100-240VAC outlet
Plug the green male connector from the power supply into the driver power input, making sure the connection location and polarity are correct, as shown.
Connecting power to driver
On the power supply, confirm that the LED is lit up, which indicates that your power supply is receiving power. Depending on your version of the power supply it may glow green or blue.
LED on power supply
