Laser Test Lightburn Files
Initial Test
This Lightburn file was designed for testing laser functionality after assembly and setup, so that you could get a good idea of how the laser is working as-is, then adjust to improve performance. You can download the file here.
Specifically, the following variables can be changed and observed for this test:
- Speeds
- Lines
- Text
- Cutting
- Images
- Digital power settings
- DIP switch power settings
- Lenses
- Materials
You can use this test project as a reference if you ever need to replicate the results for other projects. Just change the text in the file to keep track of the test file variables.
