May 20, 2026
MK3 Unboxing
X-axis Box
- 1x X-axis Assembly
- 1x Y-axis Drag Chain
- 1x X-axis Drag Chain
- 1x Z-axis Box
- 1x Z-axis Assembly
- 1x Motor Covers Set with M3-40mm Screws
- 1x 65mm Router Mount
- 1x 24V 4A Power Supply
- 1x SLB-LITE Kit with USB cable
- 1x 1.2Nm Closed Loop Motor
- 1x Motor Cable Set
- 1x Hardware Box
- M5-8mm Screws
- M5-12mm Screws
- M5-25mm Screws
- M5-50mm Screws
- M4-12mm Screws
- 3/4” Wood Screws
- M5 T-nuts
- M5 Washers
- 4x Aluminum Standoff
- 1x Inductive Sensor
- 2x Integrated Bump Stop (1 extra)
- 1x LongMill MK3 wrench
- 1x 4mm Allen Key
- 1x 3mm Allen Key
- 1x 2.5mm Allen Key
- 1x AutoSpin T1 Router (Beginner’s Kit only)
- 1x MK3 Dust Shoe (Beginner’s Kit only)
- 1x AutoZero Touch Plate (Beginner’s Kit only)
- 1x Starter End Mill Set (Beginner’s Kit only)
Y-axis Box
- 1x Left Y-axis Assembly
- 1x Right Y-axis Assembly
