Manual Mode
The AutoSpin can be used in manual mode, so you can change the speed using the dial on the router. To activate manual mode:
1. While the router is OFF, turn the dial to a desired speed from 1-5
2. Turn ON the router using the “I” switch position
Please note you cannot switch between manual mode and spindle mode while the router is on – this is a built-in safety feature.
The estimated speed (RPM) for each setting on the dial can be found below.
Setting | 1 | 2 | 3 | 4 | 5 |
Speed (RPM) | 10,000 | 15,000 | 20,000 | 25,000 | 30,000 |
