Software is a crucial part of running a CNC machine, and we have many articles and videos to explain how to choose and use these programs.
πŸ’‘Just getting started? Read this introductory article on the types of CNC software you’ll need, and this systems requirements page on what specs your computer needs to have. If you have the gControl panel, that’s great! It can run both design (CAM) and g-code sending programs, but we recommend plugging in a keyboard and mouse if you want to do detailed design work.
πŸ”Ž Deciding on which design (CAM) software to use? The video below compares a wide range of programs.
πŸš€ Looking for a g-code sending program that is easy, capable and compatible with your 4×8? Check out gSender, developed and maintained by our in-house team of software engineers. You can learn more about its features on the gSender resources pages.
🏁 Ready to prepare and run g-code? These final key resources will prepare you for success.
  • Post-Processors – when you export your g-code in the design (CAM) program, a post-processor formats your g-code so the machine can correctly interpret the instructions. See here for compatible post-processors for different CAM programs, for your AltMill 4×8.
  • Vectric VCarve – see these video tutorials for step by step instructions.
  • Machine Coordinates and Setting Zero – these fundamental concepts of 1) how to set the starting location of your job, and 2) how the machine keeps track of where it can travel to, are appliable to virtually every CNC, from hobby to industrial-level. Learn about them in this article. This will enable you to successfully home and zero your machine on gSender.
  • gSender – This video overview is comprehensive, running through important gSender features and showing how to run a CNC job
