4×4 & 2×4 Specifications
The AltMill represents the pinnacle of hobby CNCing, bringing industrial-level technologies to a price point and ecosystem for both beginners and advanced users.
The AltMill uses a robust aluminum frame construction, with optimized aluminum extrusion profiles to maximize rigidity and ease of assembly. The machine is fully complete, and standalone without the need for an existing workbench or table surface.
Size Machine Dimensions Cutting Area Drawings
2×4 1598 x 975 x 1438 mm
(62.9 x 38.4 x 56.6″)
1265 x 635 x 174 mm
(49 x 25 x 6.8″)
MK2 2×4 Key Dimensions
4×4 1598 x 1575 x 1438 mm
(62.9 x 62 x 56.6″)
1265 x 1251 x 174 mm
(49.8 x 49.25 x 6.8″)
MK2 4×4 Key Dimensions
See here for the table leg drawings: AltMill Table Leg Dimensions
For more detailed dimensions, refer to the available 3D CAD model found in our Open Source page
Carton Sizes & Weights
For the 4×4 machine:
  • Package 1, 62x11x11 (in) 76 lbs (X rail box)
  • Package 2, 62x11x11 (in) 70 lbs (Y rail box)
  • Package 3, 37x10x11 (in) 73 lbs (Main box)
For the 2×4 machine:
  • Package 1, 42x11x9 (in) 77lbs
  • Package 2, 42x11x 9 (in) 60lbs
  • Package 3, 63x12x11 (in) 76lbs
For the Spindle Kit:
  • 15x13x5 (in) 20 lbs
Requirements & Specs
Power requirements:
With a 1.5KW Spindle
We recommend allocating two 15A 110V/120V single phase circuits — one for the spindle and dust collection system, the other for the machine and a computer.
If you live in a country with 220V/240V power you should use a transformer to convert to 110V/120V.
  • To solely run the machine, you need a rating above 500W
  • To run the machine and spindle, you need a rating of 2000W, do not use GFCI breakers with spindles
The 1.5KW spindle uses NEMA 5-15P power plug.
With a 2.2KW Spindle
We recommend allocating at minimum one 15A 110V/120V single phase circuit for the machine and one 15A 220V/240V single phase circuit for the spindle. Computer and dust collection can go on any of the two circuits as needed.
If you live in a country with 220V/240V power you should use a 500W transformer to convert to 110V/120V for the machine
The 2.2KW spindle uses NEMA 6-15P power plug.
Max cutting speed: 15000 mm/min (590.5 ipm) in X and Y, 6000 mm/min (236.2 ipm) in Z
X, Y, Z-axis motion: 15mm square profile precision ground hardened steel rails, fastened to rigid aluminum extrusion rails, with sealed linear bearings
X & Y axis power transmission: 2.0NM integrated closed-loop NEMA 23 steppers driving 16mm, 10mm lead ball screws. Ball screws fixed with matched pair angular contact bearings.
Z-axis power transmission: 1.2NM integrated closed-loop NEMA 23 steppers driving a 12mm, 4mm lead ball screw. Ball screw fixed with matched pair angular contact bearings.
Power supply:
  • Input: 100-130 VAC 50/60 Hz, 7-54 Amps
  • Output: 48 VDC 10 Amps, 480 Watts
  • Comes with a North American Standard Type B NEMA 5-15P plug.
Find specifications about add-ons here:
