General Information
***Included with your AltMill 4×8***
- SLB-EXT controller and emergency stop
- Partially pre-assembled rigid frame
- Inductive sensors for homing
- Sturdy metal legs with the ability to add 4ft wide shelving underneath
***Not included with your AltMill 4×8***
Check out our recommended products tabs for an ideal set up, but note the following ARE NOT included with your order:
- Computer or laptop
- Spindle
- End mills or bits
- T-tracks
- Waste board (e.g. MDF 4ft x 8ft sheet)
- Set of metric Allen keys, standard bits or drill for assembly
The AltMill 4×8 does not come with an ATC System or Spindle Kit. They must be purchased separately.
| Size | Machine Dimensions | Cutting Area |
| 4×8 | 1676 x 2896 x 975 mm (66 x 114 x 38.4″) |
1265 x 2460 x 210 mm (49.8 x 104 x 8.3″) |
See here for the table leg drawings: AltMill Table Leg Dimensions
Carton Sizes & Weights
For the 4×8 machine:
1x 4×8 Supplemental Parts Box – 40lb, 18”x8”x22”
1x 4×8 Leg Box – 75lb, 38”x11”x12”
2x 4×8 Rail Box – 70lb, 66”x11”x12”
1x Table Support Box – 42lb, 64”x11”x12”
1x 4×8 X-axis Rail Box – 70lb, 66”x11”x12”
Power Requirements
2 Outlets required: 1x 120 VAC for the AltMill, as well as 1x 120 VAC or 220 VAC single phase for the optional spindle.
AltMill (SLB-EXT Control Board)
- 100/130 VAC – 10A to the control board, Type B NEMA 5-15P plug.
Spindle
- 1.5kW spindle kit, 100-130 VAC, 15A, Type B NEMA 5-15P plug
- 2.2kW spindle kit, 220-240 VAC single phase, 20A, NEMA 6-15P plug
If you live in a country with 220V/240V power we recommend using a transformer to convert to 110V/120V for the control board or get a high quality 220V power supply, comparable to our power supply.
- To solely run the machine, you need a rating above 500W
- To run the machine and 1.5KW spindle, you need a rating of 2000W
I would like to source my own spindle, what should I be aware of?
- For spindles 2.2KW or above, you will need to install extra 220VAC wiring
- The AltMill comes with an 80mm spindle mount, we do not have larger diameter mounts at the moment
- The VFDs that may work with our controller are: Huanyang v1, Huanyang P2A, Yalang YL620, H-100, and GS20, however they are not plug-and-play — read this article for further information
Specifications
Max cutting speed: Approx. 25,000 mm/min (1,000 IPM) in Y-axis; 16,000mm/min (590 IPM) in X-axis; 6,000mm/min (236 IPM) in Z-axis
Repeatability: ±0.05 mm (±0.002″)
Motion System: Rack and pinion using precision gearbox reduction on Y-axis; 16mm precision ball screw on X-axis; 12mm precision ball screw on Z-axis
Linear Motion: 15mm profiled linear guide rails and bearing blocks on all axes
Drive Motors: High-Torque NEMA 23 Closed-Loop Stepper Motors. 3NM torque on Y-axis; 2NM torque on X and Z axes.
Control System: SLB-Ext 32-bit controller with grblHAL firmware
Power Requirements: 120VAC, Single Phase, 4A (Spindle power requirements listed separately)
Weight: Approximately 400lbs as assembled, not including weight of add-ons such as spindles
Spindle Mount: Supports 80mm spindles and routers
Frame Construction: Rigid frame and linear motion design using HGR15 linear guides and ball screws on all axis mounted to a custom-designed, machined aluminum extrusion; with sturdy metal legs with the ability to add 4ft wide shelving underneath for sheet goods
Materials capable of cutting:
- Woods: Softwoods, hardwoods, plywood and MDF
- Plastics: Acrylic, PVC, HDPE, Polycarbonate and ABS
- Composites: Carbon Fiber, Dibond and ACM
- Non-Ferrous Metals: Aluminum, brass and copper (with appropriate lubrication/misting and cutting strategies)
- Ferrous Metals: Carbon steel, alloy steel and cast iron (with appropriate lubrication/misting and cutting strategies)
- Foams: High-density sign foam and insulation foam
Add-Ons
Find specifications about add-ons like the spindle, AutoZero touch plate and gControl panel on this page.
