Manual Mode
The AutoSpin can be used in manual mode, so you can change the speed using the dial on the router. To activate manual mode:
1. Ensure the router is off
2. Turn the dial to a desired speed from 1-5, speed chart below
3. Turn ON the router using the “I” switch position
Please note, you cannot switch between manual mode and spindle mode while the router is on – this is a built-in safety feature.
The estimated speed (RPM) for each setting on the dial can be found below.
Setting 1 2 3 4 5
Speed (RPM) 10,000 15,000 20,000 25,000 30,000
