ATC Specifications
What’s Included
In each ATC Spindle Kit, you will receive:
  • 2.2KW ATC Spindle
  • ATC Spindle Mount
  • Enclosed 2.2KW VFD and Mount Adapter
  • Clear Cut Dust Shoe
  • Tool Length Sensor
  • ATC Expansion Board for an SLB-EXT Controller
  • 2.2KW VFD NEMA 6-15P Power Cord
  • 10M Length 8mm Air Line Tubing
  • Male 1/4″ NPT to 8mm Air Line Push Fitting
  • ER20 Collet Wrench
  • All cables and harnesses
For the specific ATC Spindle Kits:
ATC 6-Tool Rack Kit
  • 1 Tool Rack (holds 6 tools total)
  • 6 ISO20 Tool Holders
  • 12 ER20 Collets, for (3x) 1/8″, (4x) 1/4″, (3x) 3/8″, (2x) 1/2″ bits
ATC 12-Tool Rack Kit
  • 2 Tool Racks (holds 12 tools total)
  • 12 ISO20 Tool Holders
  • 24 ER20 Collets, for (6x) 1/8″, (8x) 1/4″, (6x) 3/8″, (4x) 1/2″ bits
ATC Spindle Only
  • 3 ISO20 Tool Holders (No tool rack)
Not included in the ATC Spindle Kit:
Compatibility
Machines: All sizes and models of the AltMill are compatible with our ATC. Our ATC is not compatible with third-party CNC machines.
Reduction in Machine Travel (Y-axis):
5.3″ from the back of the machine, accounting for clearance for the Clear Cut Dust Shoe.
Remaining Machine Travel (Y-axis):
  • 2×4: 20.3″
  • 4×4: 43.5″
  • 4×8: 99″
Note that the tool rack is detachable, so it can be removed to free up the full cutting area.
Minimum Requirements
Electrical
ATC Power: Air manifold, pressure and temperature sensors utilize the SLB-EXT’s existing power supply.
Total System Power:
3 separate electrical circuits, to provide:
  • 110 VAC 15A single phase for the AltMill (SLB-EXT with ATC hookup), dust collection, and computer
  • 220 VAC 15A single phase for the 2.2KW spindle
  • 110 or 220 VAC 15A single phase for your air compressor
Customer Supplied Air Compressor
  • Operating Pressure: 100 psi
  • Airflow: 3 CFM (ft³/min) at 90 psi or better
  • Filter: 40 µm or better, coalescing type
  • Dryer: More information to be provided
Product Details
Spindle
  • Output Power: 2.2 kW
  • Speed: 7,500–24,000 RPM, constant torque beginning at 18,000 RPM
  • Collet: ER20
  • Bearings: Ceramic
  • VFD power plug style: NEMA 6-15P
ATC
  • Cooling: Air cooled with 24V fan
  • Operating Noise: 60 dBA at 24,000 RPM
  • Tool Holder: ISO20
  • Collet Type: ER20 collets
  • Tool Rack Size: Maximum tool diameter 2″, maximum shank diameter 1/2″
  • Number of Slots: 6 or 12 (configuration dependent)
Weights and Sizes
Main ATC Box
22″x22″x8″, 35lb
ATC Tool Rack (6 Tools)
7″x7″x22″, 12lb
ATC Air Filter Regulator
5″x5″x12″, 3lb
