What to Expect in the Main Box
Your gControl Panel Computer will arrive with two boxes:
Box 1 contains the computer itself.
Box 2 includes the mounting hardware and accessories.
Here’s what you should receive:
Computer Box:
- gControl Panel Computer.
Mounting Parts Box:
- G-shaped Panel Mounting Clip.
- VESA Plate.
- Pillar Stand.
- (2)Plastic Clip.
- Arm Mount Bracket.
- Hardware bag (M-A,B,C).
- Hardware bag (G,J,K,L).
- Monitor Arm.
- (2)Wi-Fi Antennas.
- Power Cord.
- (6)M5x8mm + (6)M5 Flat washers (for arm mount bracket).
- Extra bag with plates, and a small bag containing (4)M4x5mm Pan Head Screws (for VESA plate installation on the back of the machine).
- Monitor Desk Mount Manual. PDF version here.
You may not need to use all the items provided, as some extra parts are included.
For attaching the VESA plate to the back of your machine, be sure to use the four (4) M4x5mm pan head screws, as shown in the image below.
Although the manual refers to using M4x12mm (M-A) or M5x12mm (M-B) screws, those are too long and won’t fit properly. Instead, use the M4x5mm screws (highlighted in the green square) as recommended.
Notes:
- The screen comes with a protective film that can be removed for better touchscreen response. Check the System Specifications for more details.
- For the AltMill MK2 please remove the one screw on the Y-end plate to install the mounting bracket (for the silver one only).
