Skip to content
  • AltMill 2×4 / 4×4
    • The Basics
    • Specifications
    • Assembly
    • Handbook
  • AltMill 4×8
  • LongMill MK2
    • The Basics
    • Assembly
    • Handbook
    • Advanced
    • Setup & Layout
    • Using gSender
    • Additional Features
    • Edge Features
    • Problems / Bugs?
    • GRBL Alarms
  • SLB
    • Upgrading to SLB
    • Technical Manual
    • Firmware & Flashing
  • Add-ons
    • ATC
    • AutoZero Touch Plate
    • Clear Cut Dust Shoe
    • Closed-Loop Motor Kit
    • gControl Panel
    • Laser
  • Fundamentals
    • The Basics
    • Handbook
Return to Main Site
  • AltMill 2×4 / 4×4
    • The Basics
    • Specifications
    • Assembly
    • Handbook
  • AltMill 4×8
  • LongMill MK2
    • The Basics
    • Assembly
    • Handbook
    • Advanced
    • Setup & Layout
    • Using gSender
    • Edge Features
    • Problems / Bugs?
    • GRBL Alarms
  • SLB
    • Upgrading to SLB
    • Technical Manual
  • Add-ons
    • ATC
    • gControl Panel
    • Laser
  • Fundamentals
    • The Basics
    • Handbook
Return to Main Site
Explore
  • Home
  • Assembly
Assembly
  • Unboxing
  • Introduction
  • Mounting Laser Assembly
  • Cables and Connections
  • Driver Power Supply
  • Turning Driver On
  • Setting Max Current DIP Switch
  • Installing Lens
  • LightBurn Settings
  • gSender Settings
  • Test Out Your Laser
  • Focusing
  • Set XY Zeros
  • Vortex Riser Mount
  • Magnetic Mount
Home » LaserBeam » Assembly
Sienci Labs Resources
