Basic Toolchain
The Sienci Mill One uses different types of software which work together to take your ideas and turn them into physical objects. The following video will explain how all CNC routers use this ‘toolchain’ to carve your desired object.
The CAD, CAM, and G-code Sender pages that follow will further explain how to either use our recommended software package, or use another existing software that is compatible with your machine.
