Skip to content
  • Fundamentals
    • 4×8
    • 2×4 / 4×4
    • MK3
    • MK2
    • MK1
    • Setup & Layout
    • Using gSender
    • Edge Features
    • Problems / Bugs?
  • Controllers
    • SLB / SLB-EXT
  • Add-ons
    • ATC
    • Closed Loop Upgrade
    • AutoZero Touch Plate
    • Clear Cut Dust Shoe
    • gControl Panel
    • Laser
    • Spindle VFD
    • TLS
Return to Main Site
LongMill MK1
  • Fundamentals
    • 4×8
    • 2×4 / 4×4
    • MK3
    • MK2
    • MK1
    • Setup & Layout
    • Using gSender
    • Edge Features
    • Problems / Bugs?
  • Controllers
    • SLB / SLB-EXT
  • Add-ons
    • ATC
    • gControl Panel
    • Laser
    • Spindle VFD
    • TLS
Return to Main Site
  • Home
  • LongMill MK1
  • Software Table
Software Table
12097 March 9, 2026
Choosing which software you want to use with your LongMill can be a daunting task. Below is a list of software we’ve tried along with details that might help you find your toolchain.
Tags: mk1
< Previous Page
Visualizers
Next Page >
System Requirements 📊
Pages
  • The Basics
    • Welcome!
    • CNC Routers
    • Feeds & Speeds
    • Materials
    • Workholding
    • Routers / Spindles
    • Dust Collection
    • Touch Plates
    • Table / Enclosure
    • Common CNC Terms
    • Software Explained 🗣️
    • Choosing Software 🎛️
    • Post Processors
    • Visualizers
    • Software Table
    • System Requirements 📊
  • Assembly
    • Unboxing 📦
    • XZ-Axis Gantry
    • Y-Axis Gantries
    • X-Axis Rail 📏
    • Y-Axis Rails
    • Drag Chains and Wiring
    • Electronics
    • Table Mounting 📐
    • Starter Projects 🧱
    • Assembling Add-ons
    • 48" Extension Kit
    • Wasteboard Surfacing
    • Sanding & Finishing
    • More Projects 🪑
    • Maintenance 🛠️
    • Common Issues & Fixes 🩹
  • Advanced
    • Open Source & Modifications 🥽
    • Noise, EMI, & Grounding
    • Tool Changing
    • Inductive Sensors
    • Custom Limit Switches
    • IOT Relay Control
    • Adding a Laser
    • grbl Firmware
    • EEPROM Settings
    • Adjusting Stepper Driver Current
    • Changing Microstepping
    • LongBoard Details 🤖
LongMill MK1 » Software » Software Table
Sienci Labs Resources
