1. Unboxing 📦
Make sure you have all the parts you need for a smooth and painless assembly; open all boxes and unwrap the parts, except for the plastic on the left and right Y-axis rails!
Drag chains are stored inside the rails, please check there.
AltMill MK2 Kit Parts List
X-Axis Rail Box
  • 1x X-Axis Assembly
  • 2x Drag Chain – packaged inside the X-axis assembly
  • 1x 48V 10A Power Supply
  • 3x Crossbeam Extrusion
  • 1x 4mm Hex Key
  • 1x 3mm Hex Key
  • 1x AltMill Wrench
  • X-Axis Fastener Bag
    • 2x Eccentric Bushing
    • M4-16mm Socket Head Cap Screws
    • M5-10mm Socket Head Cap Screws
    • M5-16mm Socket Head Cap Screws
    • M5-20mm Socket Head Cap Screws (Note: these screws are no longer used on AltMill kits received after July 2025, but are packed in some early shipments. These screws can be discarded.)
    • M6-25mm Button Head Cap Screws
    • M6-35mm Flanged Button Head Cap Screws
    • M6 Shoulder Screws
    • M5 Nylock Nut
  • Table Assembly Fastener Bag
    • Crossbeam M5-18mm Tall Socket Head Cap Screws
    • M6-14mm Button Head Cap Screws
    • M6 Twist-in T-nut
    • M5 T-nuts
Y-Axis Rail Box
  • 1x Left Y-Axis Assembly
  • 1x Right Y-Axis Assembly
  • 4x Y-axis End Plate
  • 2x Crossbeam Extrusion (4×4 only)
Main Box
  • 4x Table Leg
  • 1x Left Y-axis Gantry Plate
  • 1x Right Y-axis Gantry Plate
  • 3x Closed Loop Stepper Motor
  • 1x 80mm Spindle Mount
  • 1x Z-Axis Assembly
  • 4x Leveling Feet
  • SLB-Ext Box
    • 1x SLB-EXT Controller with Enclosure
    • 1x 3D Printed E-stop Mounting Plate
    • 1x SLB E-Stop Button Module
    • 1x SLB E-Stop Cable
    • 1x USB-C Cable
  • Hardware Box
    • 1x Drag Chain Bracket
    • 8x Integrated Sensor Bump Stop (Note: AltMill kits received before July 2025 will receive 6x Rubber Bump Stops which follow a slightly different assembly procedure outlined later on)
    • 4x Coupler
    • 4x 3D Printed Cable Hanger Clip
    • Zip Ties
    • 4x Inductive Sensor with Pigtail
  • 4x Motor Covers with M3-40mm hardware
  • X, Y1, Y2, Z Motor Cables
Spindle Kit Box
  • 1.5KW or 2.2KW Spindle
  • 1x VFD Mounting Bracket OR 3D printed Bracket
  • Spindle Accessories Bag
    • 1x ⅛” ER20 Collet
    • 1x ¼” ER20 Collet
    • 1x ⅜” ER20 Collet
    • 1x 1/2” ER20 Collet
    • 1x ER20 Nut Wrench
    • 1x ER20 Shank Wrench
  • VFD Unit
    • 1x VFD AC Power Cable
    • 1x VFD RS485 Cable
    • 1x Spindle Cable
  • Dust Shoe Box
