VIDEO
Make sure you have all the parts you need for a smooth and painless assembly; open all boxes and unwrap the parts. Check for missing parts using the lists below.
Package Contents
ATC Box
Part Name
Qty
Notes
Sienci ATC
1
In foam
ISO20 Tool Holder (Spindle Only Kit)
3
In foam
MicroSD Card
1
ATC Shield (SLB-EXT)
1
RJ12 Cable – 0.2m
1
M4 – 8mm Flat Head Screw
7
M5 – 10mm Socket Head Screw
7
M6 – 14mm Button Head Screw
8
M6 – 25mm Button Head Screw
5
M5 Lock Nut
5
M6 Shoulder Screw
2
Eccentric Bushing
1
4mm Allen Key (Ball end)
1
2.5mm Allen Key
1
2mm Allen Key
1
1/2″ NPT Straight Fitting (8mm)
1
ATC Drag Chain Arm
1
Z-Plus Drag Chain Bracket
1
2×4/4×4
ISO20 Wrench Set
1
2.2kW Enclosed VFD
1
VFD Controller Cable
1
VFD Mounting Spacer
1
M5 – 30mm Socket Head Screw
4
M5 Lock Nut
2
Sienci TLS
1
TLS Cable
1
M5 – 10mm Button Head Screw
2
M5 T-nut
2
Z-axis Drag Chain
1
2×4/4×4
Plug-In Spindle Cable
1
2×4/4×4
Plug-In Spindle Cable – 7.2m
1
4×8
ATC Signal Cable
1
8mm Pneumatic Tubing
1
240V VFD Power Cord
1
ER20 Collet Set (Spindle Only Kit)
1
12 pcs
ATC Mounting Plate
1
Cable Clips
4
Cable Ties
4
Dust Shoe (Packed in ATC Box)
Part Name
Qty
Notes
Upper Dust Shoe
1
Lower Dust Shoe
1
4″ Hose Clamp
1
Clear Cut ATC Bracket
1
Clear Cut ATC Front Gasket
1
Clear Cut ATC Rear Gasket
1
Clear Cut ATC Slider Bushing
2
ATC Hose Bracket
1
M4 – 4mm Button Head Screw
4
M5 – 16mm Socket Head Screw
4
2
M6 Washer
3
Dust Shoe Handle
2
Filter Regulator Box (Add-on)
Part Name
Qty
Notes
Auto Drain Filter Regulator
1
3/8″ BSPP Straight Fitting (8mm)
2
Quick-Disconnect Ball Valve
1
Tool Rack Box (6 Tools)
Part Name
Qty
Notes
ISO20 Tool Holder
6
ER20 Collet Set
1
12 pcs
Tool Rack Backbone
1
Front Rack Section
2
Back Right Rack Section
1
Back Left Rack Section
1
Support Extrusion
1
Tool Holder Clip
10
Tool Rack Knob
2
M4 – 8mm Button Head Screw
20
5
M6 – 8mm Button Head Screw
12
M3 – 20mm Socket Head Screw
2
M6 Twist-In T-nut
5
M6 Roll-in T-nut
7
ATC Rack Sensor
1
ATC Rack Sensor Cable
1
Cable Clips
4
Cable Ties
4
