Product Details
Sienci Labs Spindle Kits are developed to be as ‘plug and play’ as possible with the AltMill CNC system. All spindles go through a break-in process in-house, and all VFD units are pre-programmed and tested before shipment.
Currently we have released 3 variations:
- ER16 1.5KW – discontinued as of September 2025
- ER20 1.5KW
- ER20 2.2KW
Each ER20 kit comes with the following:
- Air-cooled, 24,000 RPM spindle
- A VFD unit with pre-installed cables for spindle control and power
- 1.5KW – 110V
- 2.2KW – 220V
- ⅛”, ¼”, ⅜” and ½” ER20 collets
- M25x1.50mm collet nut
- Two spindle wrenches
- VFD mounting bracket
- RS485 cable
- Dust shoe kit
The ER20 collet size accommodates cutting bits up to 1/2″ in diameter.
Each spindle is 80mm in diameter, mounted using the AltMill’s 80mm spindle mount. The height at which the spindle sits at can be easily adjusted to fit a specific setup/project’s needs by loosening the two M5-25mm clamping screws at the front of the mount.
The VFD unit is mounted on the inside corner of the front left table leg of the AltMill using the included VFD mounting bracket. If you’d like to mount this elsewhere, this can be screwed into any surface using the two diagonal screw holes on the corners of the VFD. You’ll want to ensure this is mounted at least 2” away from any other objects or walls, and that the upper fan intake on the unit is not covered/restricted. You’ll also want to make sure that it doesn’t sit in any area where it may be prone to intake dust through its air intake.
To communicate with the machine’s controller system, a serial communication protocol known as ‘RS485’ is used. This allows the control system to not only send commands to the spindle system, but to also receive feedback from the spindle system, such as spindle speed.
For detailed instructions on setting up the spindle VFD, see below:
General Information on spindles:
