10. Final Checks
Mechanical
  • All screws in the table frame have been tightened
    • End plates with T-nuts
    • End plates to Y rails
    • Crossbeams to Y rails
    • Clamping nuts on levelling feet
    • Legs to frame
  • Table is level on all 4 corners of the machine
  • All couplers have been fully tightened on both the motor shaft and ballscrew sides
    • You may need to unfasten from the ballscrew side to check the motor shaft side
  • Grease has been applied to the gear rack
Electrical
  • Motor DIP switch positions are correct for each axis
X and Y-axis motor, from 1-5: OFF, OFF, OFF, ON, ON
Z-axis motor, from 1-5: OFF, OFF, ON, ON, ON
  • Motor cable wires are not frayed or detached from connectors
    • If they are simply detached, you can use a small screwdriver to press each orange spring terminal release to insert the wire back in
    • You may need to remove the motor cover to check
  • Inductive sensors are functional
    • Check by putting a metal object near the blue sensor face and see if a small red light triggers on the back
  • Spindle VFD is plugged in to a separate circuit from the SLB-EXT control board
  • You are using gSender version 1.6.2 or newer
    • Older versions of gSender do not support the ATC
  • Alarm 10 can be cleared using the “Click to Unlock Machine” on gSender, after pressing and releasing the E-stop button
  • Machine can jog in the X, Y and Z directions smoothly using the jog control buttons
  • Machine can jog over the table joint without any clunking sounds
  • Spindle can spin up to speed, without alarms or errors, using the CW or Forward button
  • Machine is able to successfully home without alarms or errors
    • Jog the machine away from the X, Y and Z sensors
    • Then press “Home”
If you have gone through the checks above, then you are ready to start cutting!
Encountered troubles? Check our 4×8 troubleshooting guide.
What’s next?
