Who this Guide is for
This assembly guide is for our MK2 Altmill. This assembly guide includes updated wiring harnesses and bump stops for machines shipped July 2025 and newer. If your machine shipped with stainless steel dust shields, please refer to the MK1 Assembly process here.
Tips
Before you dive into the assembly of your machine, we have a few recommendations to make your experience a good one:
- Due to the weight of the components, it’s best to assemble the AltMill with another person.
- The expected assembly time is between 3-5 hours, so make sure to allot ample time and pace yourself to avoid any errors, damages or injury during the process.
- Use the appropriate tool for each fastener. You may use a drill or driver for quicker assembly, but be careful not to overtorque screws.
- Before tightening fasteners, take note of whether they should be firmly or loosely secured. Some steps will require that screws initially be left loose so that components can be aligned in later steps.
- Keep the AltMill packaging as some of it will be used in the assembly process
- Ensure at least 6’x12’ of clear working space to set up the machine’s table/base
- It’s recommended that hardware is kept its respective bag until needed to make finding the correct type easier using the attached labels
- If you are uncomfortable with using software, we highly recommend you have a computer-savvy friend or family member to help you with the final few steps, starting from the First Movements article
Videos
If you prefer video, you can watch the following videos.
Note that any updates to our instructions will be reflected in the written instructions, so if something is not working after following the video, please read our assembly articles!
Ben’s MK2 assembly video covers the steps described in the following articles:
Unboxing, Table Setup, Gantry, Z-axis Assembly Motors, Drag Chain Ends, Wiring and Spindle, and Controller Setup.
Daniel’s video below covers the remaining AltMill setup processes as described in the following articles:
First Movements, Spindle Kit Setup, and Wasteboard.
